JD I-match
/ JD I-match #11
diyDave said:
:confused: What size tractor are you trying to pull the aerway with? You need at lease 40-45 hp to pull this implement with (at full penetration), so the size of the hitch is moot if your tractor is too small for the implement.:eek:
Really? Then I guess I can't be using mine with my John Deere 3320. I'll have to remember that the next time I use it.
Aerway recommends a minimum of 25hp for the 6-foot model. In fact, if you look at an Aerway brochure, they show a 6-foot model being pulled with a Kubota L2550 - a 27hp tractor. The local golf courses use JD & Kubota CUTs with turf tires to pull the ones they use.
/ JD I-match
Thanks guys. I have a JD 5103 50 hp. will pull it just fine. the aerway has the bolt through pins on it but are about 1 1/2 inches to short on each side to match up. my first thought was longer bolt throughs but was thinking the may bend being too long? maybe a pc of soid round stock all the way through and welded the the supports. sorry about the respond time but I when fishin?? jb
/ JD I-match #13
Look very carefully at the factory pins. On my Aerway, the pins have a shoulder on them. The holes in the outer support are 1-1/8 inches diameter, and the holes in the inner support are 7/8-inches diameter to fit the standard 7/8-inch pins that oriented toward the center of the implement.
This configuration makes the pin 1-1/8 inches in diameter for the distance from the outside of the outer support to the inside of the inner support. The remainder of the pin is 7/8-inch diameter.
Finding a pin that is two separate diameters may be difficult. You might want to take the factory pins out, and just bolt a standard hitch pin of the correct length to the inner support with the pin oriented toward the center of the implement.
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
ATTENTION PLEASE READ (A60462)
ATTENTION PLEASE...
