JD Hy-Guard compatibility....??
/ JD Hy-Guard compatibility....?? #1
bswiv
Palatka, Fl
CAT D5G, Kubota M8540, KubotaB2700
Friend gave me about a gallon each of John Deere Hy-Guard hydraulic fluid......low viscosity and regular.......
Not wanting to waste it I'm wondering whether I am safe using it in my Cat D5G for the hydraulic system......or in my M8540 Kubota's hydraulic system?
What is it compatible with?
/ JD Hy-Guard compatibility....?? #2
Pretty much all trans/hydraulic fluids are completely compatible. They have to be when there are so many hydraulically-driven attachments, implements, and rentals.
Hy-Gard is top quality. Look it up. They used to publish a table of other fluids that met the same quality specs.
/ JD Hy-Guard compatibility....?? #3
A gallon? Toss it in with the used oil. Why risk a contamination/compatibility issue over a gallon or two of oil?
/ JD Hy-Guard compatibility....?? #4
JD Hy-Gard & Kubota hyd oils are very compatible. There's no risk involved mixing the 2 brands of oil. I utilize Hy-gard in my Kubota M7040 transmission case
/ JD Hy-Guard compatibility....?? #5
My tractor is suppose to use the low viscosity Hy Gard. They sold me the regular kind for my first change and the low viscosity for the second. I didn’t catch it until the second change so mine is a blend, no problems.
/ JD Hy-Guard compatibility....?? #6
Not sure of the age of your Cat but are you sure it doesn’t use TDTO - Cat’s Transmission and Drive Train Oil, which has different additives than ag hydraulic oil.
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Tailgate Mulcher Portable Hay Blower (A65579)
Tailgate Mulcher...
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
New/Unused Electric Winch (A65583)
New/Unused...
Gravely Zero Turn Mower (A64194)
Gravely Zero Turn...
