JD 8760 overheating
/ JD 8760 overheating #1
ironman7
manitoba
JD8760
I have purchased a used JD8760 recently which seems to overheat randomly. I use 50 antifreeze solution. There seems to be excess pressure in the rad. I have blown out the rad, changed thermostats, and replaced the water pump. Does anyone have any suggestions or had this issue?
/ JD 8760 overheating #2
Do you have to add antifreeze often . If so you may have a blown head gasket . That will cause alot of pressure in the rad. It will blow out the coolant
/ JD 8760 overheating #3
It might be the clutch fan. A guy I know had to replace his because it was overheating on his 8760.
