JD 8760 overheating
/ JD 8760 overheating #1
ironman7
manitoba
JD8760
I have purchased a used JD8760 recently which seems to overheat randomly. I use 50 antifreeze solution. There seems to be excess pressure in the rad. I have blown out the rad, changed thermostats, and replaced the water pump. Does anyone have any suggestions or had this issue?
/ JD 8760 overheating #2
Do you have to add antifreeze often . If so you may have a blown head gasket . That will cause alot of pressure in the rad. It will blow out the coolant
/ JD 8760 overheating #3
It might be the clutch fan. A guy I know had to replace his because it was overheating on his 8760.
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
PALLET OF 2CYL GAS ENGINE/RADIATORS AN PARTS (A67714)
PALLET OF 2CYL GAS...
2023 Polaris Ranger 4x4 Gas Utility Cart (A66734)
2023 Polaris...
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
