JD 8760 overheating
/ JD 8760 overheating #1
ironman7
manitoba
JD8760
I have purchased a used JD8760 recently which seems to overheat randomly. I use 50 antifreeze solution. There seems to be excess pressure in the rad. I have blown out the rad, changed thermostats, and replaced the water pump. Does anyone have any suggestions or had this issue?
/ JD 8760 overheating #2
Do you have to add antifreeze often . If so you may have a blown head gasket . That will cause alot of pressure in the rad. It will blow out the coolant
/ JD 8760 overheating #3
It might be the clutch fan. A guy I know had to replace his because it was overheating on his 8760.
IRANCH Tire Changing Machine (A64194)
IRANCH Tire...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
213098 (A64276)
213098 (A64276)
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
1991 Brenner 307 SS Single Comp Insulated T/A Chemical Tanker Trailer (A64194)
1991 Brenner 307...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
