JD 8760 overheating
/ JD 8760 overheating #1
ironman7
manitoba
JD8760
I have purchased a used JD8760 recently which seems to overheat randomly. I use 50 antifreeze solution. There seems to be excess pressure in the rad. I have blown out the rad, changed thermostats, and replaced the water pump. Does anyone have any suggestions or had this issue?
/ JD 8760 overheating #2
Do you have to add antifreeze often . If so you may have a blown head gasket . That will cause alot of pressure in the rad. It will blow out the coolant
/ JD 8760 overheating #3
It might be the clutch fan. A guy I know had to replace his because it was overheating on his 8760.
2025 International MV607 S/A 5/6 Yard Mason Dump Truck (A64194)
2025 International...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
2017 Jeep Grand Cherokee SUV (A64557)
2017 Jeep Grand...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
