JD 8760 overheating
   / JD 8760 overheating #1
ironman7
manitoba
JD8760
I have purchased a used JD8760 recently which seems to overheat randomly. I use 50 antifreeze solution. There seems to be excess pressure in the rad. I have blown out the rad, changed thermostats, and replaced the water pump. Does anyone have any suggestions or had this issue?
   / JD 8760 overheating #2
Do you have to add antifreeze often . If so you may have a blown head gasket . That will cause alot of pressure in the rad. It will blow out the coolant
   / JD 8760 overheating #3
It might be the clutch fan. A guy I know had to replace his because it was overheating on his 8760.
   / JD 8760 overheating #4
Yes it may be . Sometimes we overlook the basics . Maybe that is what it is.
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
2013 Ford F-150 4x4 Pickup Truck (A51692)
2013 Ford F-150...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
