JD 850D Gator users
/ JD 850D Gator users #1
kuboman
Canada
B3200, L5740,
A :confused:question about these units. When mine is in neutral the transmission freewheels some and the only way to get it into gear is to grind things. Is this normal or do I have something wrong?
/ JD 850D Gator users #2
If it shifts easily with the engine turned off, your idle rpm is set too high.
Slowing the idle might help a bit but the problem is with the tranny in neutral it turns so easy that the slight belt drag on the engine pulley turns the tranny too.
/ JD 850D Gator users #4
Sounds like the clutch needs to be blown out. Check your manual, there should be a how-to on taking the cover off the clutch and blowing the dust out. If there's too much dust and dirt inside the clutch housing the clutch won't completely disengage.
8ft Fork Extensions (A61572)
8ft Fork...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
