JD 850D Gator users
/ JD 850D Gator users #1
kuboman
Canada
B3200, L5740,
A :confused:question about these units. When mine is in neutral the transmission freewheels some and the only way to get it into gear is to grind things. Is this normal or do I have something wrong?
/ JD 850D Gator users #2
If it shifts easily with the engine turned off, your idle rpm is set too high.
Slowing the idle might help a bit but the problem is with the tranny in neutral it turns so easy that the slight belt drag on the engine pulley turns the tranny too.
/ JD 850D Gator users #4
Sounds like the clutch needs to be blown out. Check your manual, there should be a how-to on taking the cover off the clutch and blowing the dust out. If there's too much dust and dirt inside the clutch housing the clutch won't completely disengage.
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 FREIGHTLINER...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2025 Spirit Electric Scooter (A61574)
2025 Spirit...
