JD 790 WON'T MOVE .........
/ JD 790 WON'T MOVE ......... #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
:confused: Was using my 790 w/FEL to set stone, you know, the typical New England stacked stone fences you see visitng New Hampshire, loading bucket with single stone at a time to easily set into place, up to 120 lbs. Shut the tractor down, parking brake on, took a short break, came out and started right up. Freely shifts into all gear pattern and nothing not-ta. No signs of grinding as I depress the clutch which was strong (so I thought, but what do I know) before my timely break, all the hydraulics work.. I'm thinking to myself, not a good day for stone fence work........ Told the wife on a positive note, didn't happen in the dead of winter. Any tips for me to further troubleshoot to understand better the issue before I tow it back up to the house...... THANKS
/ JD 790 WON'T MOVE ......... #2
I suggest pulling the top of the transmission off...I think your shifter linkage has come apart. Probably a roll pin worked loose.
/ JD 790 WON'T MOVE ......... #3
Could it be something as simple as the Hi-Low Range shift lever being in neutral?
/ JD 790 WON'T MOVE ......... #4
Boy, that would be embarrassing!
But I hope you're right!
2013 Bomag BM-211D Single Drum Vibratory Soil Compactor (A61572)
2013 Bomag BM-211D...
(2) Bell 500 Gal Saddle Tanks (A64119)
(2) Bell 500 Gal...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2017 International 4300 Box Truck (A62613)
2017 International...
2018 International HX620 Quint Dump (A62613)
2018 International...
