JD 790 WON'T MOVE .........
/ JD 790 WON'T MOVE ......... #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
:confused: Was using my 790 w/FEL to set stone, you know, the typical New England stacked stone fences you see visitng New Hampshire, loading bucket with single stone at a time to easily set into place, up to 120 lbs. Shut the tractor down, parking brake on, took a short break, came out and started right up. Freely shifts into all gear pattern and nothing not-ta. No signs of grinding as I depress the clutch which was strong (so I thought, but what do I know) before my timely break, all the hydraulics work.. I'm thinking to myself, not a good day for stone fence work........ Told the wife on a positive note, didn't happen in the dead of winter. Any tips for me to further troubleshoot to understand better the issue before I tow it back up to the house...... THANKS
/ JD 790 WON'T MOVE ......... #2
I suggest pulling the top of the transmission off...I think your shifter linkage has come apart. Probably a roll pin worked loose.
/ JD 790 WON'T MOVE ......... #3
Could it be something as simple as the Hi-Low Range shift lever being in neutral?
/ JD 790 WON'T MOVE ......... #4
Boy, that would be embarrassing!
But I hope you're right!
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2012 FOR F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FOR F150...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A67714)
PALLET OF 2 SHOP...
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
