JD 790 300 loader
   / JD 790 300 loader #1
adamls78
east Georgia
05' Johndeere 790
I just wanted to know if anybody thinks the 300 loader is on the weak side or if it is just mine.
   / JD 790 300 loader #2
You can increase the maximum hydraulic pressure on the 790 by putting in a shim kit.
   / JD 790 300 loader
Put a shim kit where?
   / JD 790 300 loader #5
On the relief valve...This has been discussed a lot in the forum-it seems the 790's have very a very low pressure setting from the factory. You will NEED a gauge setup to adjust the pressure. It's not the loader's fault:D
   / JD 790 300 loader
Where do you get the kit from and has anybody had problems with hoses blown off after the kit was installed
   / JD 790 300 loader #7
JD -- AM875169 SHIM ***'Y, RELIEF 2.68 2.68 Stock.
I've had no problems. I put all the shims in the kit in. I think some have put multiple kits in. Certainly if I was going with more than one kit I would check the pressure when the relief valve kicks in.
   / JD 790 300 loader #8
That part # is a bag of shims. Any JD dealer should be able to order it for you. Definitely the best 2$ modification for a 790. While your there, get the o-ring for the pressure regulator. I didn't check the link, but I assume it's the one with pictures and instructions. They recommend the o-rings to be replaced, and sure enough when I dis-assembled mine, the o-ring broke and turned the 20 minute job into a 2-day job, cause I had to go get parts.
You won't be popping stumps out of the ground, but after the kit is in you'll be able to easily lift a bucket full of wet GA clay, I mean dirt!
   / JD 790 300 loader #9
Ordered 2 shim packs for my 790/300 yesterday. Shimming the relief valve to 2500psi seems to be what most 790 owners have done on tbn. I could be wrong but I think it would be safe to shim the pressure up to 2600-2700psi. The 3005 Hydraulic System has a working pressure of 2422-2698 psi. Both tractors have the same hydraulic pump, same part number. I believe the slightly larger flow rate of the 3005 (10.3 gpm) over the 790 (9.6 gpm) is due because of the higher pressure. I have a gauge and quick coupler setup to accurately adjust the pressure so we will see.:)
But... like I said before, I could be wrong.:eek:
   / JD 790 300 loader #10
The online specs I see for the 3005 are:
Hydraulics
Type Open Center
Pump Rated Output, gpm (L/min.) 9.4 (36.4)
Steering 4.2 (15.9)
Implement 5.4 (20.5)
Pump Type Single gear (Manual steering models); Dual gear (Power steering models)
Maximum Operating Pressure (PSI) 2050
Draft Control Type Position control
Remote Control Valves Available 2
All the same as the 790. I don't think anything was changed except the name. At 2500 I would be worried about my pump and hoses and most of all being able to lift more than the tractor can handle. Just my opinion.
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A50323)
2008 Ford E-350...
Pallet Jacks (A50121)
ATTENTION! PLEASE READ (A50120)
ATTENTION! PLEASE...
2016 John Deere 5100M (A50120)
2016 John Deere...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
