JD 770 No Start/Power
   / JD 770 No Start/Power #31
Fishmen222, any update? Did you find your problem?
   / JD 770 No Start/Power #32
Removed starter and returned to shop, guy said someone has been" messing with starter the bolt has been moved" and stripped. I did not argue with him but the starter has not been messed with.I stripped the bolt trying to tighten it and replaced nut but my wife or dog hadn't been near it.Seems if the bolt was not assembled right it happened at the rebuild anyway I will let u all know after I pick it up.
Not yet. Between a sick wife and 12 hour night shifts, I have pretty much left it alone. Here is what I do know, battery, links, fuses and main cables are fine but it sure is acting like a ground issue as I have zero power beyond the main infeed to the starter. I have tried every combination of +/- with the multimeter I can think of to find the break to no avail. I am having a hard time getting to the ignition switch as I need to drill out some screws on the side panel. Which terminal is the constant and which is the "on" (not start)? I would like to jump them out to see if it could be that. My schematics leave a little to be desired. Thanks as always guys.
   / JD 770 No Start/Power #35
that was where the power stopped with mine at the starter connection.When I attached a positive cable from a known good source(auto battery) and the starter did not turn I figured that was the problem. I took it to the shop starter turned when tested.The bolt and nut was stripped,once replaced it is cranking and running.
   / JD 770 No Start/Power #36
Sorry to hear about the wife. Hope everything's gets back on track. Good luck and keep us up-dated. Thanks! Henri
   / JD 770 No Start/Power #37
Hope the wife gets better soon.
Thanks guys. The wife has been putting up a valiant decade long battle with leukemia. She's happy and feeling ok today, and that's all that matters for now. Will get into the tractor next week while on vacation and report back.
Well, found it by accident this morning. I was reinstalling the ignition switch after finding no constant power there and the ground ring sparked. Hmm...there is power at the dash. All is fine now. All I can assume is that the ground ring lost connection though there did not appear to be major corrosion on it. Thanks for all the help guys.
   / JD 770 No Start/Power #40
I'm glad you found problem and hope your wife does well.
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
2014 BMW 5 SERIES SEDAN (A59575)
2014 BMW 5 SERIES...
