JD 770 No Start/Power
/ JD 770 No Start/Power #21
I am having the same problem and it seems to happen atleast once a season .JD 4200 tractor.Last yr. after checking ,measuring ,replacing parts as posted solutions I let the dealer have it.I was told battery has to be at 13.5+ to start so Then it was bad battery. Last month after sitting a couple weeks, charging one yr. old battery still no crank. So I jumped it with truck started and run.I let it sit for a couple weeks ,no crank and will not jump. Took battery to shop ,good.starter rebuilt last year,
/ JD 770 No Start/Power #22
I think your dealer is mistaken, a common wet cell battery fully charged is about 2.1 volts/cell or 12.6 volts. Most batteries will read a little higher if you measure them right after charging up but this "overcharge" will dissapate quickly. Maintaining a good cranking voltage while starting the tractor is more important. Charging voltage is usually higher around 14+/- volts to expedite the process.
You might have something that is slowly draining the battery and will help with this if it appears it is the case later in the trouble shooting.
If you wan't to diagnose your tractor starting issues just go through the trouble shooting steps outlined in my first post. Battery voltage at terminals before trying to start, then battery voltage while cranking starter, voltage from battery neg to end of battery cable/ solenoid terminal, battery neg to s terminal on solenoid and last battery neg to starter terminal.
Let me know what you get
/ JD 770 No Start/Power #23
As stated already, 13.5 volts is more than what is needed to start your tractor. 13.2~14.5 volts is an acceptable range for an alternator to supply back to a battery that has a load on it like headlights, etc.
No battery will hold that amount of voltage when the tractor is off. In order for the charging system to work a certain amount of voltage over the amount being used by the tractor must be returned to the battery or it will go flat and not start the next time due to insufficient voltage present. This is the combined job of the alternator/voltage regulator. Confirming what was said about a draw on your battery by some circuit when the tractor is at rest, especially over several weeks, is a likely culprit and will eventually kill even a good battery. Batteries are not meant to go from full to empty- this can and will greatly shorten their life expectancy. They ARE meant to go from full to about 80% of full charge and then be recharged via the alt/v reg.
/ JD 770 No Start/Power #24
Thanks I get 12v at battery,starter and alternator but no crank,no click at starter.still nothing when jumped directly.I am thinking the starter is the problem.
/ JD 770 No Start/Power #25
The starter or the start switch may be the problem.
That is why I asked you to measure from the neg batt terminal to the s terminal on the solenoid. If you get 12v at the s terminal while engaging the start switch then the solenoid or starter look suspect. If you aren't getting voltage at the s terminal the start switch is suspect. Before you assume the switch or solenoid is bad you need to verify a few things.
/ JD 770 No Start/Power #26
Yes it is 12 v at starter with key on.When I touch cable to starter there is spark and slight click.
/ JD 770 No Start/Power #27
What cable are you touching to the starter (solenoid?). To clarify further, when you say with key on are we talking about on or cranking position?
/ JD 770 No Start/Power #28
Positive from battery to starter while cranking,switch and solenoid replaced 2 yrs ago
/ JD 770 No Start/Power #29
OK, so what about the starter? You replaced both the solenoid and ignition switch 2 years ago, yes? Why both? And what was the starter's status at that time? Good, marginal?
Sounds like you may be where you were 2 years ago. Can you remove the starter and have it checked out by a reliable rebuilt shop?
/ JD 770 No Start/Power #30
Yes I contacted the shop today so that is the next step.thanks I will let u know.
/ JD 770 No Start/Power #31
Fishmen222, any update? Did you find your problem?
/ JD 770 No Start/Power #32
Removed starter and returned to shop, guy said someone has been" messing with starter the bolt has been moved" and stripped. I did not argue with him but the starter has not been messed with.I stripped the bolt trying to tighten it and replaced nut but my wife or dog hadn't been near it.Seems if the bolt was not assembled right it happened at the rebuild anyway I will let u all know after I pick it up.
Not yet. Between a sick wife and 12 hour night shifts, I have pretty much left it alone. Here is what I do know, battery, links, fuses and main cables are fine but it sure is acting like a ground issue as I have zero power beyond the main infeed to the starter. I have tried every combination of +/- with the multimeter I can think of to find the break to no avail. I am having a hard time getting to the ignition switch as I need to drill out some screws on the side panel. Which terminal is the constant and which is the "on" (not start)? I would like to jump them out to see if it could be that. My schematics leave a little to be desired. Thanks as always guys.
/ JD 770 No Start/Power #35
that was where the power stopped with mine at the starter connection.When I attached a positive cable from a known good source(auto battery) and the starter did not turn I figured that was the problem. I took it to the shop starter turned when tested.The bolt and nut was stripped,once replaced it is cranking and running.
/ JD 770 No Start/Power #36
Sorry to hear about the wife. Hope everything's gets back on track. Good luck and keep us up-dated. Thanks! Henri
/ JD 770 No Start/Power #37
Hope the wife gets better soon.
Thanks guys. The wife has been putting up a valiant decade long battle with leukemia. She's happy and feeling ok today, and that's all that matters for now. Will get into the tractor next week while on vacation and report back.
Well, found it by accident this morning. I was reinstalling the ignition switch after finding no constant power there and the ground ring sparked. Hmm...there is power at the dash. All is fine now. All I can assume is that the ground ring lost connection though there did not appear to be major corrosion on it. Thanks for all the help guys.
/ JD 770 No Start/Power #40
I'm glad you found problem and hope your wife does well.
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2002 Volkswagen Jetta Manual Sedan (A64557)
2002 Volkswagen...
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 HINO 195 18FT...
TIGER MOWERS TRF102-102" REAR FLAIL MOWER (A63276)
TIGER MOWERS...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
More info coming soon. (A64557)
More info coming...
