JD 755 Project
/ JD 755 Project #1
lumberbean
Maryland
John Deere 755
I was finally able to purchase a JD 755 with FEL and finish mower. The tractor has over a 1000 hours on it and has some rust as you see in the pictures. The one major issue with it is that the hydrostatic transmission stopped working. The previous owner was able to purchase a new tractor so he didn't finish fixing it. The furthest he got was to get the output drive off the tractor and get replacement parts, new washer and bolt. The issue with the hydro trans is that the bolt and washer sheared off of the output drive and fell into the transaxle. I got the tractor back to my house with the help of my brother-in-law and his friend and a nice wench from Harbor Freight.
Now I just need to get the tractor back up and running. First things first is to retrieve the bolt head and washer in the trans axle. I bought a couple of retrievable magnet tools off of amazon and hope they can do the trick. I really don't want to disassemble the trans axle but I guess I will if the magnet tools don't work. I know that there's an upgrade to the output drive that JD has but when calling the local dealer, the parts department guy wasn't able to find it. Does anyone happen to know what this part number is?
Currently, the tractor from what I see needs the following:
-New Grill
-New Taillights
-New Gas Tank
-New front headlights - ones above the grill
-New Paint
My plan is to work on fixing the tractor to an operating state and then work on the cosmetics and other things that need fixing. I have no experience working on tractors but hope that with enough resources out there, I can do a lot of the work on my own since money is tight. I do have the operator's manual, maintenance manual, and parts manual for reference. I might even try to make some youtube videos if there's enough time. Anyways here's the tractor.
/ JD 755 Project #2
Sounds like a good plan, get it usable then see what else it needs before you spend any money on cosmetics. I'd put a cheap LED bar on the ROPS so you can use it after dark, the OEM lights in the hood aren't very bright anyway. Once you start using it you'll probably find some oil leaks, hydraulic hoses seeping, etc. Then you'll want some implements, etc etc.
/ JD 755 Project #3
I will enjoy seeing how you fix this tractor up but let's be honest, the "nice wench from Harbor Freight" sounds pretty appealing. Pictures?
/ JD 755 Project #4
What is always intriguing about those x55 series tractors is the size of the FEL bucket. :shocked:
It's huge compared to the size of the tractor itself. (!!!)
They have some serious hydraulic power and are a very desirable machine imo.
Best of luck and we're here for you if needed.
:wrench:
P.s. Yes HFW (Harbor Freight Wench) deserves a seperate thread. A nation-wide "HFW-of-the-Day" thread perhaps? :eek:die:
:wrench:
/ JD 755 Project #5
Had a 755 back in the day and it was a great tractor. Hope all goes well with your project. Ed
/ JD 755 Project #6
Awesome project. I would love to find a fixer upper like that. I bought a fixer upper JD 950 but need a fel for it.
/ JD 755 Project
Thank you guys for the responses back, I'm looking forward to working on the tractor and sharing my progress with you guys. I was finally able to work on the tractor and try to fish out the washer and bolt head in the transaxle using the magnet tools from Amazon. After about 30-45 minutes of trying, I wasn't able to get them out. I did hear the magnet catch onto something and then heard one of the two fall off when I was taking it out. I'm now looking at removing the transaxle from the tractor in order to get them out since I don't want them sitting in there.
I have no experience in working on tractors, let alone removing a transaxle from any piece of equipment. Has anyone done this before on their tractor? And if so, how long did it take to disassemble and reassemble? My thoughts going in on this is, I'll need a jack, some jack stands, and impact wrench. Is there anything else I'm missing? And this might be a dumb question but I have to ask, will it mess with the structural integrity of it?
And another thing, what do you guys use to clean your tractor? Its been sitting outside for pretty much all its life and there's a lot of grime on it and was wondering what's the best cleaner to use. A friend of mine mentioned Simple Green and that sounds good but wanted to get some opinions first. I'll have to take a picture of the output drive and upload it to let you see how bad it is. Thanks for all the help.
/ JD 755 Project #8
/ JD 755 Project #9
My first suggestion is that you purchase the genuine JD Workshop (Technical) Manual. It has all the step-by-step instructions for your planned operation.
Read it 3 times before commencing work.
Now, you can buy the manual from JD as a hard-copy book and/or a CD Rom (for half the price). The book is awesome to have in your hands. You can flick back and forward with ease, mark pages, compare pics on various pages etc. This is not cheap but it will be a great 'investment' for you.
Don't be tempted to buy a cheaper non-JD manual (I refer to your acknowledged lack of experience. You need the best manual you can get. Get the JD one)
The CD is useful to Print pages from as you need them and if they get dirty, print a new copy.
I would buy both book & CD in your case.
You will also need a flat concrete floor to work on and an Engine Crane with some lifting strops or slings.
The Tech. Manual has a simple trick for use to help you -
To dismantle the Trans find the section called Transmission Disassembly.
Before you dismantle the trans you have to get it out. Find the section called Transmission Removal & Replacement.
Before you remove the trans you have to remove the seat base etc. Find the section called Seat Base Removal.
Before you remove the seat you have to remove the wheels. Find the section called Wheel Removal...
Can you see how it progresses? The sections are not in that order - You need to skip back and forward which is why printing pages as you need them is useful to create your own custom procedure manual.
Don't deride JD for this! The reason they write the manual like this is simple. They only write one procedure once. They refer you to other required procedures as necessary. On the CD they use 'live links' which helps but can get you side-tracked. So having the book version helps a lot too.
The manual will help you remove all the gear lever knobs etc needed to enable you to remove the mudguards and sheet-metal.
The manual will also help you disconnect the hydraulics safely and reconnect everything back up in the correct order. And it will show you how to disconnect control rods and linkages etc. Leave the FEL on the tractor, It will help stabilise the chassis with the rear wheels removed.
It (CD version) will also help you cut/paste sections to here for more guidance if necessary.
Once you have the sheet-metal off. refit the rear wheels and roll the machine outside to wash the grime off as thoroughly as possible. It is easier to work on a clean machine and you can see small clips etc better.
P.s. You need all Metric tools to work on this machine. All fasteners are metric.
:wrench:
/ JD 755 Project #10
Good tips so far, however I wouldn't leave the loader on. Put it outside out of the way if you have the means to get it off your dead tractor. Cut small wedges of wood and hammer them in between the front axle and the frame on both sides so it doesn't flop back and forth once you split the tractor. If you don't have an engine hoist you can use a bottle jack on one side and a floor jack on the other. Block the stationary wheels so you don't accidentally knock it off the bottle jack when you're going apart or back together.
You can find cheaper versions of the JD manual in a PDF download. I paid about $20 for mine and have printed the sections out as I've needed them. The book is nice to have, but I saved the money to spend on parts ;)
/ JD 755 Project #11
Sure Tex, but I was thinking LB has no tractor experience - so removing the loader was something he could forget until after he is able drive the tractor forward & back. FEL removal is easy if you can drive the tractor. (Which he can't right now.)
Plus we don't have to go through the "How do I remove the FEL" posts yet. ;)
I only have seen two of those cheaper downloadable pdf manuals and unfortunately both were missing crucial sections. One was MF, one was JD.
In LB's case here, he can't afford to be missing any info. That's why I suggest the genuine manual.
Regards,
:wrench:
/ JD 755 Project #12
Those early John Deere 755s etc were painted with a money saving one step no primer process. Eventually the paint would lose adhesion and peel off panels in fairly big pieces but mostly after it was out of warranty. I fought with Deere to replace a number of panels like fenders, side panels etc that had that affliction. They and dealer helped out. You end up with fairly big areas of rust.
Sometimes how much fun a project is depends on how fast you need to get it done. Obviously an important consideration with those loose pieces in the case is knowing exactly what is in there so you know you retrieved them all. My 755 with 1050 hrs has been very reliable. I have always lubed and changed fluids/filters more frequently than specified. I'll be doing their major service on it shortly that includes trans axle fluid and all filters. Good luck.
/ JD 755 Project
@ Yourkie: That's nice to know about the rust issue as I can literally peel off big size pieces without any issues. Later on down the road, I plan to use rattle can paint on it and see how it does.
@ Spanner and texasranger. I'm going to try a few more times to retrieve the bolt and washer because taking off the transaxle will be pretty time consuming. I do have the technical manual for it and thank you for the sections to look up. I'll be sure to read them over and over again.
@ beenthere: I appreciate the cow magnet link, never heard of such a thing. I'm wondering if I could feed my magnet tool up through the drain plug or put a compressor in there and try to blow the pieces up?
I'll post back next week and let you guys know if I have any success with retrieving the bolts.
/ JD 755 Project #14
Would it work to lift the front of the tractor up to help the bolts roll the the back of the trany? Would that make it easier for you?
/ JD 755 Project
Just wanted to give a quick update, I was able to get out the bolt head tonight! I'm hoping I'll be able to get the washer later on this week.
/ JD 755 Project
Another update on the 755, I was able to fish out the washer from the trans-axle a couple of Tuesdays ago! Needless to say, I was over joyed by this and ordered the updated hydro shaft for the transmission. Here's a picture of the washer and screw head, I might have to frame them. :laughing:
The new parts came in today and I worked on cleaning up the output drive. Here's a few pics of it. I do have some questions regarding it, there's a red piece of rope/twine around the one of the screws and a metal tag on another screw with some "Made in the USA" markings. Does anyone have any idea if this is normal? I'm attaching some pics for more detail.
Lastly, the house I bought some years ago was a foreclosure and in the shed was a 5 gallon bucket of Hy-Gard, unopened. I brought in my house this week and was wondering if it would be okay to use in my tractor. Or should I just buy some new fluid to be on the safe side? Here's a pic of it.
And thank you for all the feedback so far, its been much appreciated.
/ JD 755 Project #17
If it's still sealed I'd use it. It's a far more controlled environment than the oil in your tractor sees if you parked it outside for a few years. Others may disagree.
/ JD 755 Project #18
Well done on retrieving your washer.
The oil will be ok. Just don't tip the last dregs into the trans. Oddly enough, there's usually a bit of sediment in the bottom and you may have some condensation precipitate - but that's unlikely. (Don't shake the bucket around.)
Remove the red string. Leave tags if not attached by red string.
/ JD 755 Project #19
I hate to rain on some of your good fortune but... If I remember correctly your tractor uses low viscosity Hi-Guard. If that's the case you might be able to find a dealer that will trade you.
/ JD 755 Project
Thank you for the replies, I'm going to go ahead and order some low viscosity Hy-Gard. I read the technical manual and it does state to use the low viscosity. My plan is to install the new hydro shaft this week and work on installing the drive in the tractor this weekend.
Just a few more questions, the technical manual states to use a lift of some sorts to drop the hydro drive in and work on re-installing it. I don't a lift of any sorts so I'm not sure the best way forward. Any suggestions? And is there a fill port to put the Hy-Gard in? I'll go back and look at the tech manual but I don't recall seeing it.
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2018 FREIGHTLINER...
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
Unused 2023 Del Morino Funny 132M Hydraulic Flail Mower Attachment (A66734)
Unused 2023 Del...
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
