JD 749 chains
/ JD 749 chains #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
Good morning,
Can I put rear chains on my 749 all steer without rubbing issues?
Thanks, Bob W
/ JD 749 chains #2
Bob
Assume this is for an X749.
The operators manual says:
Tire chains are recommended for use with most front attachments.
Nothing about having to use spacers which early AWS required.
/ JD 749 chains
As the thread title says, it is for a 749
/ JD 749 chains #5
It depends on how the rear steering linkage is set up. There were 2 different types of rear steering linkage.
If the rear steering arms are close to the tires you will need spacers to use rear tire chains.
/ JD 749 chains #6
I ran a 425 AWS for years with chains. That tractor required wheel spacers to be used with chaings. When I upgraded to my X739 I automatically ordered the spacers, mostly for the extra wide stance. However, the spacers will not work with the 54" decks (dealer should have known this but did not). The HDAP tires were hitting the gauge wheels. So I returned the spacers. With 4WD, chains aren't much needed. Extra weight might be a better option. Or HDAP tires, if you don't already have them. They do a great job of not loading up with snow. But my advice is to talk to the dealer.
/ JD 749 chains #7
My X728 climbs snow banks with HDAP tires and six suitcase weights. I push a 54" bade/snow-plow and 47" snowblower with no problem.
Mike.
/ JD 749 chains #8
I have a x744 and Dad has a x749....they both do great on hills without spacers. Dad plows 500ft of drive with no chains and part of it is a steep off-camber hill. He does have the 6 rear weights too.
/ JD 749 chains #9
Same here. I run 8 suitcase weights on a 100 lb 3pt hitch with HDAPs. My X739 climbs a steep drive way covered with a foot of snow. I can plow snows over 2' deep, and smaller ones are a breeze. Chains are not needed (not requiring chains is one of the reasons I upgraded from my 425). Of course, in Maine the situation might be different. If you can stay out in front of the snowfalls, you should be fine without chains even in Maine.
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2025 10,000lbs. Two Post Auto Lift (A64194)
2025 10,000lbs...
Skull (A64557)
Skull (A64557)
Small Cow (A64557)
Small Cow (A64557)
2005 X-L 20T TRAILER (A65054)
2005 X-L 20T...
