jd 71 flex planter
/ jd 71 flex planter #1
craig3320
i got a used jd 71 2 row 3pt flex planter, there was no manual with it and i need to know how to set it up for corn. thanks
/ jd 71 flex planter #2
I seen a manual for a 71 Flex on Ebay last week. That is a good place to start. JD dealer probably would have them also. Ken Sweet
/ jd 71 flex planter #3
Find the Yetter site, they have the manual online that you can download. Yetter makes the 71 planter now. bjr
/ jd 71 flex planter #4
Yetter does have the manual, but it is not "exactly" the same as the JD manual. http://www.yetterco.com/help/manuals/7012-150_planter_unit.pdf
The yetter manual shows planting distances based on mph, but the JD manual for the 71 does not. I have a JD manual. If you will PM me your fax number I will fax you a copy.
30 Row Spacing
Spacing / Drive Sprocket/ Shaft Sprocket/ Plate/ Plant population
7"/ 14/ 20/ 24 cell/ 29,900
10"/ 14/ 20/ 16 cell/ 20,900
With 60" row spacing you will get 1/2 of that.
Make sure you get the correct plate for your seed corn. Mine called for a B9-16. I had to search around to find it.
With the white field corn I bought I had to buy a B5-16 and B5-24x (same plate, but different # of cells).
www.lincolnagproducts had new plates, but there are several guys on ebay that have used plates. I also have an email of a guy with a bunch of used plates if you send me a PM.
Chris
thanks, still looking and still trying to adjust, how do i pm you thanks
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
2017 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2017 BOBCAT MT85...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
