jd 71 flex planter
/ jd 71 flex planter #1
craig3320
i got a used jd 71 2 row 3pt flex planter, there was no manual with it and i need to know how to set it up for corn. thanks
/ jd 71 flex planter #2
I seen a manual for a 71 Flex on Ebay last week. That is a good place to start. JD dealer probably would have them also. Ken Sweet
/ jd 71 flex planter #3
Find the Yetter site, they have the manual online that you can download. Yetter makes the 71 planter now. bjr
/ jd 71 flex planter #4
Yetter does have the manual, but it is not "exactly" the same as the JD manual. http://www.yetterco.com/help/manuals/7012-150_planter_unit.pdf
The yetter manual shows planting distances based on mph, but the JD manual for the 71 does not. I have a JD manual. If you will PM me your fax number I will fax you a copy.
30 Row Spacing
Spacing / Drive Sprocket/ Shaft Sprocket/ Plate/ Plant population
7"/ 14/ 20/ 24 cell/ 29,900
10"/ 14/ 20/ 16 cell/ 20,900
With 60" row spacing you will get 1/2 of that.
Make sure you get the correct plate for your seed corn. Mine called for a B9-16. I had to search around to find it.
With the white field corn I bought I had to buy a B5-16 and B5-24x (same plate, but different # of cells).
www.lincolnagproducts had new plates, but there are several guys on ebay that have used plates. I also have an email of a guy with a bunch of used plates if you send me a PM.
Chris
thanks, still looking and still trying to adjust, how do i pm you thanks
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2015 Bobcat S750 High Flow Rubber Tire Skid Steer (A64047)
2015 Bobcat S750...
2 Row Hipper (A64047)
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
MOBILE HOUSE SKID (A63569)
MOBILE HOUSE SKID...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
