JD 650 hydraulics weak
/ JD 650 hydraulics weak #1
gto7419
Melville, NY
JD 4115
Bought a JD 650 with loader last year. Ive noticed that the loader can lift about 400lbs to about 4 ft. Any additional weight or height leads to a very loud relief valve releasing pressure. From my reading, there are much smaller garden tractors that can lift more than that.
Any chance someone has a service manual so I can check hydraulic pressure/perform some basic maintenance?
If pressure is good and machine is in good condition, can the pressure be raised safely?
-Appreciate any help
/ JD 650 hydraulics weak #2
:welcome: to TBN
What are the records of hydro oil and filter changes? That would be my first move.
Second would be to get a copy of the service manual.
Third would be to make up a pressure gauge that you can plug into the various couplings.
/ JD 650 hydraulics weak #3
:welcome: to TBN
Ditto on testing pressure with a gauge to determine if it's in spec's.
Thanks for the warm welcome. Didn't get any maintenance history with the tractor.
Service manual would explain where to test pressure? Ive built a bunch of motors/cars, but never messed with hydraulics before.
Any idea where I can download the service manual?
/ JD 650 hydraulics weak #5
The 650 has a 7cc hydraulic pump that will flow 4.4 gpm @ 2400 rpm. The main system relief valve opens at 2050 to 2300psi @ 1500 rpm per the spec in the tech manual.
I'm under the assumption that the relief is set by a screw on the 650? Any chance someone can scan the tech manual where the page is that shows the relief valve area?
Location (A63111)
Location (A63111)
2017 Chevrolet Sonic Hatchback (A61574)
2017 Chevrolet...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
16ft. Teak Wood Table (A61574)
16ft. Teak Wood...
2018 Dodge Journey SUV (A61574)
2018 Dodge Journey...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
