JD 650 Battery Polarity Issue
Status
Not open for further replies.
   / JD 650 Battery Polarity Issue #21
Are you stating it's bad advice to attach ground lead from charger or jumper cables to a non-painted surface other than the ground post on the battery if battery is still installed in vehicle???
Not so much a discussion of where to attach the ground lead (battery terminal or non-painted surface), but bad advice to tell someone that's it's always the negative (-) lead that is the ground lead.
   / JD 650 Battery Polarity Issue #22
I'd say you need to hang out with a different neighbor...
   / JD 650 Battery Polarity Issue #23
John Deere Parts clearly shows the US market 650 tractor with round, top battery terminals has a negative ground. The parts description indicates the polarity of the non-grounded cable that connects to the main cluster. The Euro version is also clearly negative ground.
There is a china model having flat battery terminals that could be positive ground. So, are your battery terminal flat and are the frame and fenders heavily corroded? Also check to see if you have 3 forward gears and 9 reverse gears....:laughing:
   / JD 650 Battery Polarity Issue #24
JD 650/750's came from factory negative ground on battery. Parts key # CH15195 Cable POSITIVE
Could you post the parts key that corresponds to the parts pic you posted earlier?
Thanks,
CM
   / JD 650 Battery Polarity Issue #25
Thanks,
CM
parts key #7 ground cable
parts key #10 cable positive CH15195
   / JD 650 Battery Polarity Issue #26
it's bad advice to make a ground polarity assumption on the part of the charger.
since you have the option of positive, negative or case neutral ground setups in vehicles.
   / JD 650 Battery Polarity Issue #27
What you state is true BUT on the other hand the percentage of negative ground systems will outnumber the positive ground systems by a very large percentage. Probably over 99+% of vehicles will be negative ground.
   / JD 650 Battery Polarity Issue #28
I see that several of yesterdays posts to this thread have been deleted.
Who would do such a thing and why?
If a entry is removed should the author not be notified?
1984.
   / JD 650 Battery Polarity Issue #29
Probably has little to do with 1984, and more to do with grown men acting like children
   / JD 650 Battery Polarity Issue #30
1984.
It's possible the site moderator contacted them by personal messaging.
Status
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
527 (A52708)
527 (A52708)
2014 Gravely 60" Zero Turn Commercial Mower (A55973)
2014 Gravely 60"...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
