JD 6410 how do you remove this?
/ JD 6410 how do you remove this? #1
hozjob
PineBush, NY
John Deere 6410
I took the 8 bolts out, and removed the snap ring. But it doesn't budge and don't want to force anything I'm not supposed to. Pic to follow
/ JD 6410 how do you remove this? #2
See if 2 of the holes have thread in it ? Use 2 of the 8 bolts and jack if off its axle
/ JD 6410 how do you remove this? #4
Attached is a parts breakdown it may be #6 or you may have to remove the knuckle and disassemble from the backside
John Deere - Parts Catalog
It looks like this link isn't going to the correct model, change model from 310 to your 6410, then sectional index then front axles then knuckle housing.
I know on the NH's the axle bearings are from the backside of the knuckle housing.
/ JD 6410 how do you remove this? #5
Do you need to push it in a little (1/8 - 1/4")? Sometimes there are hidden snap rings holding parts together.
/ JD 6410 how do you remove this? #6
dowels around axle have loctite on them, heat dowels to 400 degrees then I made a puller to remove gear.
/ JD 6410 how do you remove this? #7
G'day tight fit from memory but a thin wedge on opposite sides should work without damaging anything
Jon
Thanks everyone!! A bit of heat, the threaded holes and a puller made quick work of it.
CASE CX160C EXCAVATOR (A65053)
CASE CX160C...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
