JD 6410 how do you remove this?
/ JD 6410 how do you remove this? #1
hozjob
Member
PineBush, NY
John Deere 6410
I took the 8 bolts out, and removed the snap ring. But it doesn't budge and don't want to force anything I'm not supposed to. Pic to follow
/ JD 6410 how do you remove this? #2
See if 2 of the holes have thread in it ? Use 2 of the 8 bolts and jack if off its axle
/ JD 6410 how do you remove this? #4
Attached is a parts breakdown it may be #6 or you may have to remove the knuckle and disassemble from the backside
John Deere - Parts Catalog
It looks like this link isn't going to the correct model, change model from 310 to your 6410, then sectional index then front axles then knuckle housing.
I know on the NH's the axle bearings are from the backside of the knuckle housing.
/ JD 6410 how do you remove this? #5
Do you need to push it in a little (1/8 - 1/4")? Sometimes there are hidden snap rings holding parts together.
/ JD 6410 how do you remove this? #6
dowels around axle have loctite on them, heat dowels to 400 degrees then I made a puller to remove gear.
/ JD 6410 how do you remove this? #7
G'day tight fit from memory but a thin wedge on opposite sides should work without damaging anything
Jon
Thanks everyone!! A bit of heat, the threaded holes and a puller made quick work of it.
3 Point Hoist (A62613)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
300 Gal Portable Fuel Tank (A64127)
300 Gal Portable...
2012 International Prostar (A63118)
2012 International...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
