JD 6210 Clutch Problem
/ JD 6210 Clutch Problem #11
Does this tractor have a hydraulic clutch? I think JD calls it a Perma-clutch.
If so, the clutch pedal operates a hydraulic valve for the clutch engagement/disengagement.
6210 doesn't have a Perma-clutch similar to the larger Rowcrop tractors such as my 4255. 6210 has a dry damper clutch with a hyd valve that controls shuttle clutches.
A quick update. I installed a new cable and that solved the problem. Turns out the cable worked fine when unhooked but under pressure it was binding.
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
2020 DRAGON ESP...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
