JD 6200 problem with the direction indication
/ JD 6200 problem with the direction indication #1
MantsjeKlaas
Burgum
John Deere 6200
Hallo,
I have a problem with the direction indication. Both sites left an right. Also the when i push on the emergency switch nothing happens.
Is there any one that have a wiring diagram of this or can help my with this problem.
thanks in advance for the help
Kind regards
MantsjeKlaas
/ JD 6200 problem with the direction indication #2
Start with the fuses: F106 10A, F107 20A
There are Diodes for the turn signals: V102 & V103
There are three relays: K111 hazard lights, K112 left signal, K113 right signal.
All of these are in Load Center (fuse box)
There is a turn signal/hazard flasher. I am not sure where it is located.
Zebrafive,
Thanks for your help
But in my manuell there is a picture of the fuse box.
I have make a picture of it so you can see what i meen.
The fuse F102 and F105 I thought this are the fuses for turn left/richt and the hazard lights.
This fuses or good.
Ol so the relays: K111,K112 and K113 or in my opinion not for turn left turn right or hazard lights
Maybe you can see on this picture something you say that can help you.
Kind regards
MantsjeKlaas
/ JD 6200 problem with the direction indication #4
What is your serial number? there are different wiring and fuses for different serial numbers. Is it a cab tractor?
Yes it is a cab tractor
But I can't find the location of the serial number
I do have found a product identification number thus is: L06200X137510
Maybe this can help you
/ JD 6200 problem with the direction indication #6
That is the serial number.. the last 6 digits specific only to your tractor..
/ JD 6200 problem with the direction indication #7
Zebrafive,
This fuses or good.
Kind regards
MantsjeKlaas
Sorry, I was thinking a made for USA tractor. You must have European edition?
/ JD 6200 problem with the direction indication #8
Looks like all power goes through the warning light switch. May be something wrong there. Here is the wiring diagram ...
