JD 5425N
/ JD 5425N #1
DLTTrekkers
Paarl South Africa
Not starting and blows a fuse when in neutral
Found the problem at the neutralswitch.
I had to get a new switch , but that switch was to long. Had to cut the plastic off the new switch and solder the old switch s wires to the new switch. 1477663582846.jpg1477663597144.jpg
/ JD 5425N
This switch is under the seat on the inside of the gearselectorhousing that needs to be removed to do the replacement
/ JD 5425N #3
Sounds like they sold you the wrong switch, but you made it work, so all is well.
Lot One (A3632137)
Lot One (A3632137)
2009 FORD CROWN VICTORIA POLICE CAR (A66091)
2009 FORD CROWN...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2014 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2014 Chevrolet...
TRANSTORE 2000 GAL STORAGE TANK (A67714)
TRANSTORE 2000 GAL...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
