JD 5425N
/ JD 5425N #1
DLTTrekkers
Paarl South Africa
Not starting and blows a fuse when in neutral
Found the problem at the neutralswitch.
I had to get a new switch , but that switch was to long. Had to cut the plastic off the new switch and solder the old switch s wires to the new switch. 1477663582846.jpg1477663597144.jpg
/ JD 5425N
This switch is under the seat on the inside of the gearselectorhousing that needs to be removed to do the replacement
/ JD 5425N #3
Sounds like they sold you the wrong switch, but you made it work, so all is well.
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2016 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2016 FREIGHTLINER...
2015 TECUMSEH BD (A67714)
2015 TECUMSEH BD...
2017 John Deere TX 4x2 Gator (A64912)
2017 John Deere TX...
Woods 3pt 5' Mower (A64912)
Woods 3pt 5' Mower...
Bush Hog 3815 (A64911)
