JD 5400 Starting Procedure
/ JD 5400 Starting Procedure #1
k2ds
Cambridge
JD 5400
My Father died a few months ago and I went home to bushhog the fields. I can not get the tractor to start. And yes it has fuel in the tank. It is a JD 5400 and I haven't driven a tractor in 30 years but I have drive alot of older tractors in my life, JD A , Farmalls, and others along with some heavy equipment.
I have never felt this dumb in my life. It will turn over but that is it. HELP!
/ JD 5400 Starting Procedure #2
It might not be turning over fast enough...try jumping the battery and cranking the engine.
/ JD 5400 Starting Procedure #3
Make sure all of the controls are in neutral. Move the hand throttle about 1/4 way up . Also make sure the pto is off. Should start as long as it has a good battery and is turning over fast enough.
Good luck
Sean
/ JD 5400 Starting Procedure #4
If it hasn't been started in a long time .. try priming the lines. There is a plunger on the fuel filter. Push it a few times. If the engines is turning over the safeties are satisfied or jumped out.
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
C&S FARMS AUCTION - IN LOVING MEMORY OF JACKSON STRICKLAND. (A64277)
C&S FARMS AUCTION...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
