JD 5115M OS Hydraulic Filter Change info :
   / JD 5115M OS Hydraulic Filter Change info :
Local JD dealer here asking $97 for spin on hyd filter :(
Is that the going rate ? :confused:
My two older JD has a hyd cartridge filter about the same size & HALF that price lol
   / JD 5115M OS Hydraulic Filter Change info : #22
My kubota HST filter is about 65.00........
Is the Kubota a spin on filter ?
   / JD 5115M OS Hydraulic Filter Change info : #24
Yes , The threaded part is machined aluminum I guess that 's the money part of the filter..... hyd filter.jpg
   / JD 5115M OS Hydraulic Filter Change info : #25
The Kubota hyd filters are 46.00 each it takes two.........So I guess 97.00 is not that bad ,but it still hurts......Can you cross it over to a wix/napa filter?
No it’s JD only.
Plastic housing best I can tell.
   / JD 5115M OS Hydraulic Filter Change info : #27
Outrageous what they charge for filters but when the dealer is your only option your at there mercy. That plastic filter can't be a hi pressure filter either which are usually more expensive . What about the trans fluid and engine oil , do you run the hi dollar jd branded ? I've got that 5115m coming in December and not sure if I will go w the jd fluids or not.
I’ve always ran the JD HyGard Fluid in all my tractors.
It stays the pretty gold color way longer than other fluids I’ve used on lesser equipment.
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2019 BRADCO/PALADIN 116720 FORK CARRIAGE (A51243)
2019...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
Ferris 52in Zero Turn Mower (A51694)
Ferris 52in Zero...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2001 MACK RD688S ROLL OFF TRUCK (A51243)
2001 MACK RD688S...
