JD 5115M OS Hydraulic Filter Change info :
   / JD 5115M OS Hydraulic Filter Change info :
Local JD dealer here asking $97 for spin on hyd filter :(
Is that the going rate ? :confused:
My two older JD has a hyd cartridge filter about the same size & HALF that price lol
   / JD 5115M OS Hydraulic Filter Change info : #22
My kubota HST filter is about 65.00........
Is the Kubota a spin on filter ?
   / JD 5115M OS Hydraulic Filter Change info : #24
Yes , The threaded part is machined aluminum I guess that 's the money part of the filter..... hyd filter.jpg
   / JD 5115M OS Hydraulic Filter Change info : #25
The Kubota hyd filters are 46.00 each it takes two.........So I guess 97.00 is not that bad ,but it still hurts......Can you cross it over to a wix/napa filter?
No it’s JD only.
Plastic housing best I can tell.
   / JD 5115M OS Hydraulic Filter Change info : #27
Outrageous what they charge for filters but when the dealer is your only option your at there mercy. That plastic filter can't be a hi pressure filter either which are usually more expensive . What about the trans fluid and engine oil , do you run the hi dollar jd branded ? I've got that 5115m coming in December and not sure if I will go w the jd fluids or not.
I’ve always ran the JD HyGard Fluid in all my tractors.
It stays the pretty gold color way longer than other fluids I’ve used on lesser equipment.
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
GIYI GY-CWG72- 72" HYD CURVED WOOD GRAPPLE (A51244)
GIYI GY-CWG72- 72"...
2016 Chevrolet Silverado (A50323)
2016 Chevrolet...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
UNUSED FUTURE MINI EXCAVATOR 8" HYD AUGER (A51244)
