JD 5115M OS Hydraulic Filter Change info :
   / JD 5115M OS Hydraulic Filter Change info :
Local JD dealer here asking $97 for spin on hyd filter :(
Is that the going rate ? :confused:
My two older JD has a hyd cartridge filter about the same size & HALF that price lol
   / JD 5115M OS Hydraulic Filter Change info : #22
My kubota HST filter is about 65.00........
Is the Kubota a spin on filter ?
   / JD 5115M OS Hydraulic Filter Change info : #24
Yes , The threaded part is machined aluminum I guess that 's the money part of the filter..... hyd filter.jpg
   / JD 5115M OS Hydraulic Filter Change info : #25
The Kubota hyd filters are 46.00 each it takes two.........So I guess 97.00 is not that bad ,but it still hurts......Can you cross it over to a wix/napa filter?
No it’s JD only.
Plastic housing best I can tell.
   / JD 5115M OS Hydraulic Filter Change info : #27
Outrageous what they charge for filters but when the dealer is your only option your at there mercy. That plastic filter can't be a hi pressure filter either which are usually more expensive . What about the trans fluid and engine oil , do you run the hi dollar jd branded ? I've got that 5115m coming in December and not sure if I will go w the jd fluids or not.
I’ve always ran the JD HyGard Fluid in all my tractors.
It stays the pretty gold color way longer than other fluids I’ve used on lesser equipment.
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2016 Isuzu NPR-HD 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
1985 Ford Ltl9000 Tender Truck (A52128)
1985 Ford Ltl9000...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
