JD 5115M OS Hydraulic Filter Change info :
   / JD 5115M OS Hydraulic Filter Change info :
Local JD dealer here asking $97 for spin on hyd filter :(
Is that the going rate ? :confused:
My two older JD has a hyd cartridge filter about the same size & HALF that price lol
   / JD 5115M OS Hydraulic Filter Change info : #22
My kubota HST filter is about 65.00........
Is the Kubota a spin on filter ?
   / JD 5115M OS Hydraulic Filter Change info : #24
Yes , The threaded part is machined aluminum I guess that 's the money part of the filter..... hyd filter.jpg
   / JD 5115M OS Hydraulic Filter Change info : #25
The Kubota hyd filters are 46.00 each it takes two.........So I guess 97.00 is not that bad ,but it still hurts......Can you cross it over to a wix/napa filter?
No it’s JD only.
Plastic housing best I can tell.
   / JD 5115M OS Hydraulic Filter Change info : #27
Outrageous what they charge for filters but when the dealer is your only option your at there mercy. That plastic filter can't be a hi pressure filter either which are usually more expensive . What about the trans fluid and engine oil , do you run the hi dollar jd branded ? I've got that 5115m coming in December and not sure if I will go w the jd fluids or not.
I’ve always ran the JD HyGard Fluid in all my tractors.
It stays the pretty gold color way longer than other fluids I’ve used on lesser equipment.
UNUSED FUTURE MINI EXCAVATOR AUGER SET (A51244)
UNUSED FUTURE MINI...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
1996 MEC 2548 ELECTRIC MANLIFT (A51242)
1996 MEC 2548...
2011 BMW X5 xDrive35i AWD SUV (A50324)
2011 BMW X5...
Informational Lot - Shipping (A52128)
Informational Lot...
