JD 5105 fuel issue
/ JD 5105 fuel issue #1
Birddog Dave
NW Florida
JD 5105
so I had a primer diaphragm blow a hole. Finally got the correct primer assy. I installed it this morning. Tractor primed up and ran fine for 10 minutes. Cutting at WOT. Then it just shut down like I turned off ign switch. I can shoot fluid in the intake and it will run on that. Seems to be primed to the sediment filter. I replaced the can filter behind the valve cover prior to installing new primer and sediment filters. Fuel line is new.
Is there a fuel shut off fuse or the like? Any input is appreciated.
/ JD 5105 fuel issue #2
Couple of things come to mind 1.Fuel line obstruction where the line comes out of the bottom of the fuel tank. 2.Fuel shut off solenoid
I have 12v at all fuses except the Alt and fuel solenoid.
Is there a relay or any idea where this breakdown may be and getting voltage to that fuse?
Where are my grounds for the alt and fuel solenoid on the engine?
2006 John Deere 5425 (A64126)
2006 John Deere...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2009 Bobcat T190 (A64126)
2009 Bobcat T190...
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
Galvanized metal roof Vents (A64194)
Galvanized metal...
2019 Deere 35G (A64126)
2019 Deere 35G...
