JD 500 'professional mower' starting issue
   / JD 500 'professional mower' starting issue #11
Check your grounds as well. They can reek havoc .
thanks - I have noted a 200ohm resistance in the earth wire to battery - so have made a new earth - didnt help. :(
'starting circuit shorted to battery' is the clue!. look here!. Troubleshooting
Thanks - thats where I found the code....
I managed to take off the main power relay, and powered it up - it gave me a new error code - 3-8 which isnt listed anywhere I can find....
I bought the 2500 manual online - and this does list this error code as main power fail. Its not the same machine, but is similar. Might be the oil pressure switch weirdly
   / JD 500 'professional mower' starting issue #16
I saw a post by someone that had a similar problem, and it turned out water had gotten into a connector, once he brought the mower to the dealer, the problem disappeared by itself just by time..
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2016 Ford F-450 Flatbed Utility Service Truck (A56858)
2016 Ford F-450...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2017 FREIGHTLINER CACADIA DAY CAB (A57880)
2017 FREIGHTLINER...
