JD 500 'professional mower' starting issue
   / JD 500 'professional mower' starting issue #11
Check your grounds as well. They can reek havoc .
thanks - I have noted a 200ohm resistance in the earth wire to battery - so have made a new earth - didnt help. :(
'starting circuit shorted to battery' is the clue!. look here!. Troubleshooting
Thanks - thats where I found the code....
I managed to take off the main power relay, and powered it up - it gave me a new error code - 3-8 which isnt listed anywhere I can find....
I bought the 2500 manual online - and this does list this error code as main power fail. Its not the same machine, but is similar. Might be the oil pressure switch weirdly
   / JD 500 'professional mower' starting issue #16
I saw a post by someone that had a similar problem, and it turned out water had gotten into a connector, once he brought the mower to the dealer, the problem disappeared by itself just by time..
2006 International 9400i (A55302)
2006 International...
2020 DRAGON ESP...
ALLISON TRANSMISSION (A55745)
ALLISON...
2007 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2007 Chevrolet...
2016 Morbark Chipper (A55787)
2016 Morbark...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
