JD 500 'professional mower' starting issue
   / JD 500 'professional mower' starting issue #11
Check your grounds as well. They can reek havoc .
thanks - I have noted a 200ohm resistance in the earth wire to battery - so have made a new earth - didnt help. :(
'starting circuit shorted to battery' is the clue!. look here!. Troubleshooting
Thanks - thats where I found the code....
I managed to take off the main power relay, and powered it up - it gave me a new error code - 3-8 which isnt listed anywhere I can find....
I bought the 2500 manual online - and this does list this error code as main power fail. Its not the same machine, but is similar. Might be the oil pressure switch weirdly
   / JD 500 'professional mower' starting issue #16
I saw a post by someone that had a similar problem, and it turned out water had gotten into a connector, once he brought the mower to the dealer, the problem disappeared by itself just by time..
19015 (A55788)
19015 (A55788)
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
Misc Vehicle Brake Kits (A54816)
Misc Vehicle Brake...
Toro z turn (A56857)
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
