JD 500 'professional mower' starting issue
   / JD 500 'professional mower' starting issue #11
Check your grounds as well. They can reek havoc .
thanks - I have noted a 200ohm resistance in the earth wire to battery - so have made a new earth - didnt help. :(
'starting circuit shorted to battery' is the clue!. look here!. Troubleshooting
Thanks - thats where I found the code....
I managed to take off the main power relay, and powered it up - it gave me a new error code - 3-8 which isnt listed anywhere I can find....
I bought the 2500 manual online - and this does list this error code as main power fail. Its not the same machine, but is similar. Might be the oil pressure switch weirdly
   / JD 500 'professional mower' starting issue #16
I saw a post by someone that had a similar problem, and it turned out water had gotten into a connector, once he brought the mower to the dealer, the problem disappeared by itself just by time..
Bucket (A55973)
Bucket (A55973)
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
LOT: Shop Tools: (2) Sets of Truck Ramps, Pittsburg Creeper, Step Stool, Road Cones, Rolling Stool (A59076)
LOT: Shop Tools...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
