JD 4X10 Neutral (Lever) Use
   / JD 4X10 Neutral (Lever) Use #1
del
too many
Do most of you or none of you use the neutral position on
your HST lever?
I find it about impossible to "feel it" on this 4210. I have to keep hitting one of the pedals to see if I'm really in neutral which kind of defeats the purpose of having a neutral when it's a hassle to use. The tractor has only about 10 hours on it so I'm hoping it will get better.
With it hard to find neutral I thought it weird that the
tractor would also start in "gear" or rather in "range".
Kind of double problem, can't find neutral and it starts
in gear. I don't think my Kubota BX would start in gear.
It had a two speed with the neutral in the middle and was
super easy to "feel" neutral. Changing ranges was always
full back or full forward so no problem there.
The JD, being a 3 speed, I'm guessing they didn't put the
neutral at the end as it would make changing ranges tougher
which you do far more then finding neutral.
I have another Kubota though that has a straight shifter
and you have to move it sideways to use all the positions.
It seems like that would work better for finding neutral.
Anyway I happened to be reading something on the Kubota forum
and I'm guessing that when your foot isn't on the "go pedals"
that an HST is actually in neutral and that the lever position
only keeps it from going from neutral to a gear.
I do things where I am constantly hopping on and off the
tractor. Do most of you just get off with it in "range" with
the engine running? I'm talking about getting off for 60
seconds.
The discussion on the Kubota forum also mentioned that if the
tractor is turned off in "gear" that finding neutral on an
HST with the engine off to start it would be tough. I
remember on my BX that I many times couldn't get it in gear
my gently moving the lever unless I blipped the pedal a titch.
I'm guessing that is why this starts "in gear".
I've learned to survive tractor use over the years by assuming
the worst, that it will start up, go into gear and then run
over/after me. It's disconcerting to already have it in "gear"
unless it is really in neutral when you have no weight on the pedals.
Again I'm not talking about standing in front of the tractor
or being on a hill. I also read in the owners manual that
the parking brake does not either work on four wheels or work
at all with the HST lever in neutral.
Thanks for any comments
del
Got to use the JD for an important use today, lifting the
snowmen's (er snowperson') belly's up on top of their lower
sections!
   / JD 4X10 Neutral (Lever) Use #2
On all the JD 4000 and ten series I find it hard to feel the ranges. Gear shift or hst. On the 970/990 it's really smooth and I can get perfect shifts everytime.
   / JD 4X10 Neutral (Lever) Use #3
I actually prefer to park it "In gear" and then shift to neutral after I am on and ready to start it again.
The parking break has never given me much confidence that it would be sufficient to hold the tractor in place on a significant slope.
The HST doesn't really go into a free-wheeling position when you release the pedals. In fact, it kind of shuts off the hydraulic flow.
- Rick
   / JD 4X10 Neutral (Lever) Use #4
I never use neutral, as I never get off with the tractor running.
95% of my use is in mid range and I have never even shifted into hi range. No, I don't like the stiffness of the range lever, it's basically the only control I find awkward to use.
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2020 DRAGON ESP...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
