JD 455 Steering Valve
/ JD 455 Steering Valve #1
BrisMatt
Australia
JD 455
My steering valve on my 455 is leaking out the top of the valve through an o-ring. I have found the removal process quite difficult, I have removed the bolts but now need to remove the hydraulic lines running into the valve. My question is probably very simple, but how do I undo these lines? I have attached some photos.
I have looked around on the net and it seems I need a tube wrench? I have grabbed onto the large metal section of the hose and twisted it with a pair of vice grips but it just made the hole metal tubing twist.
Thanks
Matt
/ JD 455 Steering Valve #2
That is not a "joint", that is part of the hose. Take a look at the picture from jdparts.
thanks guys, with a little Persuasion the hoses slipped out.
The valve is a mess, a previous owner has welded the steering shaft into the top of the valve, photo below.
I will need to buy a 2nd hand one from ebay.
/ JD 455 Steering Valve #5
BrisMatt, I have a good steering valve and steering shaft out of a 425 for sale. They should be the same? email me at mackman48@aol.com if you're interested.
Tom
2023 John Deere 835R (A64119)
2023 John Deere...
PALLET OF (9) HYD OIL PUMPS FOR DUMP TRAILERS (A64280)
PALLET OF (9) HYD...
(2) UNUSED 23X8.50-16 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
86 (A63290)
86 (A63290)
APPROX (100) SINGLE AXLE FENDERS (A64280)
APPROX (100)...
