JD 4500
/ JD 4500 #1
nitewowl
Keller, Texas
JD4600
Saw one of these recently and it might exactly fit the specs I'm looking for. One big question though - it was only made in 1999 according to tractortips.com. Does anyone know anything about why such a limited run? Also, does anyone know if there were/are any known common issues with this particular model?? Thanks as always.
/ JD 4500 #2
My neighbor has one. Has over 1200 hours on it with nary a problem. He has the Syc Reverser FEl and hoe. Hope this helps. It was replaced by the 4510. /forums/images/graemlins/wink.gif
/ JD 4500 #3
The 4500 was built from very late 98 through 2000
the 2000 gear drive serial numbers began at 350,001 and up
the power reverser year 2000 began at #352001.
The hundred series was Deere first step away from its tried and true X55 series (655,755,855,955). There were quite a few issues with the first ones but all problems were corrected with mandatory product improvements. If you can get the serial numbers for it, I can let you know what has been done to this machine.
/ JD 4500 #4
I had bought a new JD4500 in 1999 with the JD FEL. It was the power reverser (or whatever they call it) model. I really liked the tractor and it had great power with the loader. The only issue I had on it was that the rear 3pt hitch kept bleeding off. That was fixed under warranty and I had no other issues with it at all in the approx. 200 hours I had it.
/ JD 4500
I was able to get the serial number - #354167. Hope your still out there and will be able to check this out. Thanks. Seems the 4500 went for a couple of years at least - 99 thru either 01 or 02.
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
John Deere 6320 (A64126)
John Deere 6320...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
