JD 445 Fuel Odor
/ JD 445 Fuel Odor #1
Snap50
My fuel injected, Kawi engined, 445 tractor gives off a strong smell of gasoline immediately after being shut off. I routinely throttle down just before turning it off so I assume it's not (normally) shooting excess fuel that's not burned in time, but that could be a wrong assumption. I don't see any visible gas leaks. The tractor starts, idles and runs as it should otherwise. Any ideas what could be causing this?
/ JD 445 Fuel Odor #2
Many of the newer gasoline engines have an electric solenoid in the carburetor. When you turn off the engine it kills the spark but also shuts off the fuel to prevent engine overrun. Perhaps your shutoff solenoid (if you have one) is defective or sticking.
/ JD 445 Fuel Odor #3
Could possibly be the pressure release screw on the throttle body.. that wasn't snugged back up after releasing the pressure (done when running out of fuel) and leaks a small bit of fuel.
/ JD 445 Fuel Odor #4
OK this is confusing, is this engine a Diesel or gas ?
Snap, welcome to TBN
Richard
/ JD 445 Fuel Odor #5
If a JD 445, it is gas fuel injection. The JD 455 is diesel.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
EZ Trail 3400 (A63688)
(1) FORESTRY RIM (A64276)
(1) FORESTRY RIM...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
2015 Nissan Leaf Hatchback (A61574)
2015 Nissan Leaf...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
