JD 4400 hydro problems I need your input please.
/ JD 4400 hydro problems I need your input please. #1
Hillbilly
Platinum Member
Guys,
My tractor developed a serious problem this past Tuesday and it is currently back in the shop and the dealer cannot get it to duplicate the problem[hmmm].I need your input if you have experinced a similar problem because my dealer has no clue to what might be wrong since the problem will not duplicate itself for them.Any information you supply me I might be able to help the dealer trouble shoot this problem.
Heres the story:
About a week prior to May 30 I carried a rock up a steep incline in my bucket and was amazed at how well my tractor performed the task.I got to the main road and started travelling towards the house and I noticed something happen which felt like a lost of resistance in the Hydro-pedal and a momentary drop in speed and then the tractor started performing normally again.
Tuesday May 30: I am using the 4 in 1 loader to grapple a couple of logs and I back away and stop for a second and in the meantime I set the backblade on the ground and I get ready to raise the blade and the hydraulics will not pick it up,and at the same time I try to raise my 4 in 1 off the ground and it will not move,I try to curl the bucket and lift the front end of the tractor of the ground and no luck,well I wait a couple of minutes and everything starts functioning properly.Now I decide to go to the woods and do a little work.I start out the road on a small incline and I notice the tractor does not go up the very small incline/raised place in the road very well(just a momentary thing).
Well down in the woods I go and I pick up about a 500 lb rock and start up the hill and the tractor keeps going slower and slower and I have the engine running at 2600 rpms.I let off the hydro pedal to try and nurse this sick tractor out of the woods,I finally get it up on the road and it will not hardly crawl on the flats,the same time I notice the hydraulics are sounding funny and my engine temperature is running hotter than normal and I can feel the heat going up my pants legs, coming off the rear end .I put the tractor in 2nd and try 3rd gear and it seems to do okay on the main road,well I drive to the house about an 1/8 th of a mile and I shut the tractor off and you cannot even hold your hand on the rear end it is so hot,I decide I need to clean this thing up because it is going back to the shop and I spray a little water on it and the steam rolls off of the rear end.The bullseye on the gearbox was full and I could actually detect a scent of hydraulic oil because this thing was so hot and not a leak to be seen anywhere.
The dealer cannot get the thing to duplicate the problem,my warranty epires June 28 of this year.
<font color=red>CAN ANYONE HELP ME ?I NEED TO GIVE THE DEALER SOME IDEA OF WHAT COULD BE WRONG.</font color=red>
Thanks
Hillbilly
/ JD 4400 hydro problems I need your input please. #2
Hillbilly,
Let's do some basic "just the facts, sir".
1. How long were you operating the tractor?
2. What were the exact sequence of events to lead up to incident?
3. How about topology just prior to the incident?
4. What is the dealer doing to try to reproduce the incident?
5. Is the tractor leaning to one side or the other prior to this happening?
Sounds like a combination of inclines/slopes and what you are carrying to me which triggers the problem to me. I would have the dealer haul the tractor back to your site and do exactly what your are doing to reproduce the problem.
I wish I could provide some other insight but this is all I can think of to help.
Terry
Thanks Terry.
/ JD 4400 hydro problems I need your input please. #4
<font color=blue>…up a steep incline…and start up the hill…on a small incline…</font color=blue>
Is it possible, you have “FOD” foreign object debris (…military was foreign object damage) inside the “rear-end” body that is floating around within the hydraulic fluid… and when going up some incline… this debris (being large enough) plugs up a internal “suction” port or severely restricts the port causing this overheating/cavitation/starvation of hydraulic fluid… then when you are back on level ground… the amount of suction will keep this “debris” at this port until it randomly breaks from this suction…and starts floating around again…?
/ JD 4400 hydro problems I need your input please. #5
I'm a new forum member. Just got a used 4400 a couple of months ago and have been learning rapidly.
I had a similar problem. Soon after I got the tractor, I experienced a clogged rockshaft filter that is described on the forum. During the process of correcting that I noticed that the hydraulic oil in my tractor was overfull. The dealer said that would not harm anything. Because I have learned to never overfill engines and such, I drained it do to the recommended level (at the bulls eye). Might have been as much as a gallon of extra fluid. Afterwards as I went up a long hill I started to loss power as you describe. It stopped when I got to level ground. I continued and on another longer uphill stretch the same thing happened but I wasn't at the top of the hill so it stopped completely. I was able to turn around and back the rest of the way up the hill.
The fluid level may have been a little low as I am just now learning to lower the fel and to check the level. I added more hydraulic oil and have not had any more problems.
So maybe you should have the dealer operate the tractor up an extended slope and see what happens.
/ JD 4400 hydro problems I need your input please. #6
I have the same problem on my 4700 HST. There is a safety switch under the seat which can cause the engine to loose power if it senses that the operator is not in the seat. This only occurs when the pedals are being depressed. It always happens on a slope and never on level ground.
Tony,
This is not a problem with a safety switch.I know how the tractor acts when the safety switch is not making contact.
Did your hydro get hot like I described mine doing?Where is the rockshaft filter? There is a wire mesh filter that I have had out underneath my tractor at one time.My tractor is approaching the 500 mark which the service manual calls for the hydro oil/filter to be changed.
I am going call the dealer tommorow and recommend they drain the hydro and install new filters etc and see how the oil looks,if there is a lot of debris etc,and if they cannot get it to duplicate the problem have him bring it home to me and let me try it again.
Best regards
Hillbilly
/ JD 4400 hydro problems I need your input please. #9
Hillbilly,
The rockshaft filter is a small mesh filter located in one of the connections to the rockshaft control valve. It’s under the seat and a pain to get too. Apparently JD has had some problems with it. If it gets clogged it becomes dislodged and can cause problems with your 3 pint hitch. I found parts of my filter in the rockshaft control valve. There is a good thread on the forum. Search for rockshaft filter. I don’t think it’s related to your problem, I mentioned it because that’s how I noticed my hydraulic fluid was overfull.
I did not notice my fluid getting hot. I parked it as soon as I could, but I expect that it was. My problem was corrected just by added more fluid.
Good luck.
/ JD 4400 hydro problems I need your input please. #10
Hillbilly,
Not fer nothin',but could it have been low on fluid??I think even if it was a little low that would make a big difference,especially since the everthing on the machine is driven hydraulically,you need a certain amount of oil to keep the proper operating temp,and if was a little low and you were climbing slopes it may have been starving for fluid and heated the fluid in there over operating temp.I would check with the dealer and see if 1 the oil was at the correct level 2 if the oil smells burnt,if none of these are a factor see if the dealer will send a mechanic out to your site while you run the heck outta the thing and see if it happens again.Hope this helps,cause it sucks to have a problem and not be able to pinpoint it.
Thanks Tag,
But the bullseye is completely full when the tractor is parked on a perfectly level concrete pad.
/ JD 4400 hydro problems I need your input please. #12
Hilllbilly--my first 4400 HST (an early model) had some of the symptoms of your tractor but not all. There was never any issues with the FEL. BUT, there were many issues with the damned thing suddenly freewheeling when going down a hill or losing power going up a hill or freewheeling for an extra 20 feet on level ground and there were times that it would suddenly slip when in gear and then catch up with itself. My first clue as to the problem was when I cleaned the suction screen and found it covered with metal filings to a depth of 1/8 inch or more, and even after carefully cleaning it and changing hyd oil and filter, it still acted up until the HST tranny was replaced under warranty. At that time, I was unaware of the little rockshaft filter beneath the seat. I wonder when you changed the hyd oil and how the suction screen looked when you did?? Mike S.
/ JD 4400 hydro problems I need your input please. #13
Hillbilly,
I don't know if this could have anything to do with your problem or not, but if you haven't had the update done to the remote mounted rockshaft filter, I'd have them do it even if you had to pay for it yourself. The parts don't add up to much more than $50.00. After reading all of the stories of dislodged rockshaft screens, I had my dealer order the parts to update my 4400. We agreed that if he pulled my screen and it was still in tact, I would pay for parts and labor to install the update. I just didn't want to have to worry about it happening after the warranty was out and messing up the whole system. Well, even though I had not been experiencing any dramatic problems with my 3ph, when they pulled the housing, the screen was gone. Luckily, it had lodged in the first control valve it hit and they didn't have to go further into the tractor to find it. Since it was dislodged, they are filing the whole deal as a warranty claim. I guess it would depend on how far the little screen got in the system if it became dislodged, but if it has, it could strengthen JMIII's theory.
Hoss
Thanks Hoss,
I am forwarding him all of these posts,since he seems to be lost on what to do.
Thanks to all of you guys
/ JD 4400 hydro problems I need your input please. #15
Hillbilly,
Like I said, I have a new used JD 4400. I’ve had it for about 3 months and it’s out of warranty. I think it’s a 99 model. I had the lost rockshaft filter, the loss of power going up hill and week before last problems with my fel bucket cylinders leaking down. All hydraulic problems!! I did not find this forum until 2 days before I bought the tractor so I have not had the benefit of all the knowledge here until after the fact.
I really envy you guys with the warranty!! I got my tractor from a dealer, in the town where I work, but it’s 50 miles from home. With no warranty, I would pay for hauling the tractor back and forth to diagnose problems. Therefore, I have addressed these problems myself. The dealer is pretty helpful but not the most knowledgeable. They didn’t admit to knowing anything about the rockshaft filter. I figured that out here on the forum. The loss of power uphill seemed like low fluid and so I added fluid and that fixed that. I installed a toothbar three weeks ago and I think I caught a tooth with the bucket down and blew seals (in both cylinders!!). That was a good lesson in diagnosing hydraulic problems.
With all these hydraulic problems and the posts I have seen about problems with the 4400 hydraulics, I decided I need to change the fluid, filter and inspect the suction screen. I was prepared for the worst. Afraid I would find the screen covered with metal fillings and the fluid cooked. Without a warranty, I thought I might be the proud owner of a real lemon.
Well, I just finished the fluid change tonight and feel much better. I don’t think the hydraulics have been serviced before, at least not documented. The suction screen had a reasonable amount of trash, some gasket sealant (blue and green), dirt and a very small amount of metal. The fluid seemed OK too. A little dirty, but reasonable for 300 hours.
All in all, I think it the tractor is OK and I think I have just had a string of hydraulic coincidences. I will be very interested to see what your dealer comes up with as an explanation for your symptoms. Please keep us informed.
gewpe
Rthe dealer could not duplicate the problem I was having,He went ahead and serviced the Hydro/filters/screens per my request,he told me if the problem reoccured to contact him so he could get down there and witness the problem 1st hand,21 days left on my warranty......I bet John Deere will be glad to see the clock run out,the JD stock will probably increase 20% on the day my warranty expires.
Guys,
My loader and hydraulics and hydro was giving me a problem...well the dealer came and got it...they could not get it to duplicate.....well they bring it home and I go to the woods and everything is ok....I use the bucket to move a tree top,ok...I go a little further and the back blade will not lift,I think not again....where is the dealer when I need him?I try to back the tractor up a road with the blade down.This is not going to work.....I get off the tractor and touched the control on my 4 in 1 bucket that causes the bucket to open in the middle so I can grapple.Guess what...the blade comes up.I think something is strange,well to make a long story a little longer.....the problem all along was the loader/bucket handle that controls the grapple capability...was pulled back too far and causing the hydraulics to work all the time.The handle is stiff and does not have a good feel to it,in other words you can have it pulled back too far and not know it.Also while the tractor is in the shop,I asked the dealer to service the hydro and filter..well yesterday I get a bill in the mail for $300 + for trying to find a problem that did not exist and the hydro service. /w3tcompact/icons/eyes.gif
/ JD 4400 hydro problems I need your input please. #18
All too common of a problem Hillbilly, An add on not working the way it is supposed to robbing hyd's from the power beyond back to the 3ph. Seems to me they should have figured that out for you. Sorry to here it cost you 300 bucks to figure it out for yourself. That 4-in-1 valve shouldn't stick like that. Sounds like a good issue to reclaim some lost funds.
How do you do that?Go straight to John Deere?
/ JD 4400 hydro problems I need your input please. #20
If thats the same dealer that sold it to you and installed and set it up, I would expect them to cover the cost of not properly
adjusting it. I would begin with a polite but firm talk with the service manager, if this doen't seem to go right, ask for BOTH him and the owner to set down with you, I don't believe you will need to go past this. I've been in tractors almost 20 years, very few times after the owner gets put on the spot, do you need to go higher. Be firm but, above all be polite.
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
