JD 425 blade change
/ JD 425 blade change #1
viejo
SW MO
Kubota B7500
Can anyone tell me the size of the bolt that holds the blade on on my JD 425 with 48" mower deck? I can never remember from blade change to blade change; this time I'll write it down in my owner's manual. Thanks for the help. Viejo
/ JD 425 blade change #2
Mine has 18mm for the blades.
/ JD 425 blade change #3
Hey viejo,
The JD parts website states that the 48" deck on a 425 is a M12 X 25 bolt.
Part #19M7788.
Greg
/ JD 425 blade change #4
18 mm is the wrench size on the 54" deck under my 425, so would expect buckshot721 has called it right. :) (if that was the question :D)
And same bolt size for the 48" and the 54" decks
Thanks guys. I'll write the info down in my owner's manual this time in case I forget it again. I seem to have more and more senior moments. Viejo
/ JD 425 blade change #6
Does anyone know if a 318 snow/dozer blade fits on a 425.
/ JD 425 blade change #7
I have a bracket that will alow you to use a older blade on your machine - I don't need it anymore - send me a PM if interested - Thanks
/ JD 425 blade change #8
No, the frame is wider on the 425. You can get a aftermarket adapter but after you buy the adapter and 318 blade you are likely at the same $ as buying a blade for the 425.
2022 John Deere 5055E (A60462)
2022 John Deere...
2019 CATERPILLAR 299D2 SKID STEER (A64279)
2019 CATERPILLAR...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2018 VOLVO SD115B PADFOOT ROLLER (A64279)
2018 VOLVO SD115B...
2006 Freightliner M2 106 24ft. Box Truck (A61573)
2006 Freightliner...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
