JD 425 blade change
/ JD 425 blade change #1
viejo
SW MO
Kubota B7500
Can anyone tell me the size of the bolt that holds the blade on on my JD 425 with 48" mower deck? I can never remember from blade change to blade change; this time I'll write it down in my owner's manual. Thanks for the help. Viejo
/ JD 425 blade change #2
Mine has 18mm for the blades.
/ JD 425 blade change #3
Hey viejo,
The JD parts website states that the 48" deck on a 425 is a M12 X 25 bolt.
Part #19M7788.
Greg
/ JD 425 blade change #4
18 mm is the wrench size on the 54" deck under my 425, so would expect buckshot721 has called it right. :) (if that was the question :D)
And same bolt size for the 48" and the 54" decks
Thanks guys. I'll write the info down in my owner's manual this time in case I forget it again. I seem to have more and more senior moments. Viejo
/ JD 425 blade change #6
Does anyone know if a 318 snow/dozer blade fits on a 425.
/ JD 425 blade change #7
I have a bracket that will alow you to use a older blade on your machine - I don't need it anymore - send me a PM if interested - Thanks
/ JD 425 blade change #8
No, the frame is wider on the 425. You can get a aftermarket adapter but after you buy the adapter and 318 blade you are likely at the same $ as buying a blade for the 425.
1986 GMC C7000 Truck, VIN # 1GDM7D1G5GV542445 (A61165)
1986 GMC C7000...
International Engine (A61568)
International...
2007 Volvo VNL Truck Tractor (A63118)
2007 Volvo VNL...
International...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
