JD 4120 Hyd Screen
/ JD 4120 Hyd Screen #1
Leejohn
Elite Member
Doniphan, Mo.
Kubota L4240, B7800 & BX2660
A friend has a JD 4120 and he me asking me if he had a screen in the rear end for the hyd oil. I couldn't tell him if it did or not. Can someone please help us out? Thanks, Lee
/ JD 4120 Hyd Screen #2
Not in the rear diff, AFAIK, only in the transmission in my JD4100. There is a parts breakdown on green tractor talk that he might be intertested in looking at.
/ JD 4120 Hyd Screen #3
On my 4520 power reverser it is located where the return hydraulic fluid from filter to bottom of transmission
enters the housing. I when cleaning have found loosen filter and then to 2 bolts connecting to housing this will enable to free the line and remove from lower end 2 1.4 inch bolts will allow retainer to come off and able to pull filter out of transmission .( if you didn't remove the fluid by this time you have.)
about 10 gallon. I use a 15 gal. plastic barrow laid on side with bung on top side and funnel direct fluid into barrow.
ken
Thanks!!!! I well let him know. Thanks again!!!
/ JD 4120 Hyd Screen #5
Leejohn
There is a strainer (some might call a screen) in the "rear end" as shown in this schematic from jdparts.
It is unlike the screen on my 4300 that is located on the forward end of the transmission.. of which something similar doesn't show up for the 4120. The red arrow shows forward orientation, so looks to be rearward and over the right rear axle..
/ JD 4120 Hyd Screen #6
Leejohn
That is the screen I was referring to and the opening is at lowest portion of transmission. follow the line from hydraulic filter to the shown 2 bolt on fitting.
Man I was all over JD parts site couldn't find that picture. Many, many thanks again. Lee
/ JD 4120 Hyd Screen #10
Maybe he meant "pinched" packing, key 2, in the drawing you posted, post #5
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
Rhino RC20 (A64119)
Rhino RC20 (A64119)
John Deere 4520 (A60462)
John Deere 4520...
