JD 4110 FEL problem
/ JD 4110 FEL problem #1
bell1
Hello. I have a JD 4110 with a 410 FEL. The loader lifts fine and curls down fine. But it will only curl up about half-way and then stops. I haven't found any leaks/broken hoses. Any ideas? Could it be a cylinder?
It was working fine one day and the next day didn't curl up all the way.
/ JD 4110 FEL problem #2
There was a similar problem on here in the past few weeks. Ended up that quick disconnects needed to be unhooked and rehooked. Its cheap and always worth a try!
Just found that after I posted this. I will try that. Thanks.
/ JD 4110 FEL problem #4
Welcome to TBN:D
As suggested, unplug and re-seat all the QD's...75% of the time that fixes the problem. Good luck.
BTW...You have a great machine there, not that I am biased or anything:p
It works! Must have disconnected one somehow. Thanks again everyone!
Kennyd - yes, it is a fantastic machine. I love it!
2002 Volkswagen Jetta Manual Sedan (A64557)
2002 Volkswagen...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
