JD 4110 FEL problem
/ JD 4110 FEL problem #1
bell1
Hello. I have a JD 4110 with a 410 FEL. The loader lifts fine and curls down fine. But it will only curl up about half-way and then stops. I haven't found any leaks/broken hoses. Any ideas? Could it be a cylinder?
It was working fine one day and the next day didn't curl up all the way.
/ JD 4110 FEL problem #2
There was a similar problem on here in the past few weeks. Ended up that quick disconnects needed to be unhooked and rehooked. Its cheap and always worth a try!
Just found that after I posted this. I will try that. Thanks.
/ JD 4110 FEL problem #4
Welcome to TBN:D
As suggested, unplug and re-seat all the QD's...75% of the time that fixes the problem. Good luck.
BTW...You have a great machine there, not that I am biased or anything:p
It works! Must have disconnected one somehow. Thanks again everyone!
Kennyd - yes, it is a fantastic machine. I love it!
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2018 FORD F-150 (A65643)
2018 FORD F-150...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
County Line 4' 3-Pt Rotary Mower (A66408)
County Line 4'...
90in. Work Bench (A65640)
90in. Work Bench...
2020 Patriot 12' Enclosed Trailer (A66285)
2020 Patriot 12'...
