JD 4066R pto
/ JD 4066R pto #1
Unhitched
JD 4310
I have a John Deere 4066R that I have had for a year or so, I just purchased a chipper, and I cannot for the life of me figure out how to make the pto run when I am not in the seat. I have set the parking brake as well as put it in neutral. is there a trick for this?
/ JD 4066R pto #2
Try leaning the seat forward then start tractor
/ JD 4066R pto #3
Parking brake, neutral. Do not engage PTO while on the tractor (or the seat to be specific). That‘s how mine works. Mine is a 2017 4066R open station.
/ JD 4066R pto #4
Exactly!
The only thing I do that's slightly different is I start the engine from outside the cab (right side door), engage the PTO (at idle RPM) once the engine is warmed a bit, then increase RPM to PTO speed (about 2600 RPM).
Like Unhitched, this process is for my chipper
4052R...same machine as the 4066, but a bit less HP
/ JD 4066R pto #5
For a Kubota....you have to start pto while sitting on seat....but immediately flip seat up after getting off.
Sounds like JD may be a little different.
In any case....I guarantee it's spelled out in your owners manual.
/ JD 4066R pto
That totally worked, I never thought that I needed to engage the pto without sitting in the seat, thank you!
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2004 INTERNATIONAL RA027 4X2 S/A DAY CAB TRACTOR (A59911)
2004 INTERNATIONAL...
Informational Lot - Shipping (A63688)
Informational Lot...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
