JD 4066R pto
/ JD 4066R pto #1
Unhitched
JD 4310
I have a John Deere 4066R that I have had for a year or so, I just purchased a chipper, and I cannot for the life of me figure out how to make the pto run when I am not in the seat. I have set the parking brake as well as put it in neutral. is there a trick for this?
/ JD 4066R pto #2
Try leaning the seat forward then start tractor
/ JD 4066R pto #3
Parking brake, neutral. Do not engage PTO while on the tractor (or the seat to be specific). That‘s how mine works. Mine is a 2017 4066R open station.
/ JD 4066R pto #4
Exactly!
The only thing I do that's slightly different is I start the engine from outside the cab (right side door), engage the PTO (at idle RPM) once the engine is warmed a bit, then increase RPM to PTO speed (about 2600 RPM).
Like Unhitched, this process is for my chipper
4052R...same machine as the 4066, but a bit less HP
/ JD 4066R pto #5
For a Kubota....you have to start pto while sitting on seat....but immediately flip seat up after getting off.
Sounds like JD may be a little different.
In any case....I guarantee it's spelled out in your owners manual.
/ JD 4066R pto
That totally worked, I never thought that I needed to engage the pto without sitting in the seat, thank you!
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
Kuhn Axis 50.2 H-EMC-W Fertilizer Spreader (A64047)
Kuhn Axis 50.2...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
