1979 JD 850 2wd PTO stopped working....
   / 1979 JD 850 2wd PTO stopped working.... #1
APEHF
1978 John Deere utility tractor 2wd 3T80J
I have a 1979 JD 850 2wd with a 3T80J motor. Earlier this year the pto stopped working so I parked it till now. Where do I start so as to establish a diagnosis for this problem? I imagine that I have to remove the seat cover of the back end so as to see what is going on? Is there anything I should be careful of when removing said cover? Thank you!!!
   / 1979 JD 850 2wd PTO stopped working.... #2
Welcome to TBN
Tell us more about what "quit working" means pls. Never works or always engaged ??
Assume yours is a two-stage clutch so you have a live PTO. Is that your case ??
I have to clutch to put the pto and tramission in gear and when I clutch the pto and transmission stops turning.... And now even when I try to engage the pto it does not turn.... i will recheck my manual to make sure of what I just wrote....
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
2012 DIAMOND C 40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
