JD 320 stalls when engine gets hot/warm
   / JD 320 stalls when engine gets hot/warm #32
Pulling my carb off and cleaning it out really good did the trick for me.
Also, my fuel filter is always 1/4 full...the dealer said this is normal.
Try the oilcan trick mentioned here http://www.mytractorforum.com/showthread.php?p=3158185
That is what I will do next. It has turned cool in N KY, so it may be awhile before I can see the results. Thanks - I'll try to remember to update either way.
   / JD 320 stalls when engine gets hot/warm #33
I had the same problem with my 320 2 years ago. It was so annoying, I went and bought a 335 just so I could mow my lawn while working through it. Two of us had the same issue at that time. What worked for both of us was cleaning the pin the carb float is on. We had a small burr on that shaft and caused the float to stick, after awhile gravity set in and opened it back up. It's worth the additional 3 minutes to try it if you are cleaning the carb anyway. I used a piece of scotch brite to clean it up, but sandpaper would work fine
   / JD 320 stalls when engine gets hot/warm #34
Thank you to those who posted in this thread. I had the same issue with my 320. I ordered a carburetor from Amazon (the one with the best reviews), replaced the fuel line and filter, and the o-ring in the elbow to the air filter. It ran more the 50 minutes the first time mowing with no issues.
   / JD 320 stalls when engine gets hot/warm #35
Paul
Welcome to TBN 📣
Richard
   / JD 320 stalls when engine gets hot/warm #36
Thank you, Richard. I find the site interesting and helpful.
I hope to be able to provide something helpful in return.
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58216)
SKID STEER...
2013 BOBCAT T870 SKID STEER (A52709)
2013 BOBCAT T870...
IRanch Traffic Cones (A57149)
IRanch Traffic...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Pig Statue (A57149)
Pig Statue (A57149)
